cub 5234d transmission part lookup
   / cub 5234d transmission part lookup #1
Cub5k
Maryland
Cub 5252
I need to order some parts for a 5234d that has no readable serial numbers anywhere. The parts I need are gears for the transmission. When I do a parts lookup it asks if the tractor is 1B065G and before or 1B075G and after. I did a part lookup under both categories and the part numbers are different though the tooth count on the gears is the same. Does anyone know if there's a way to identify the correct part if the serial isn't readable?
for reference the part I'm looking for is under the transmission drive and is part #38 and #39
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2011 VOLVO VNL670 SLEEPER (A51219)
2011 VOLVO VNL670...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2016 VOLVO VHD TRI-AXLE DUMP TRUCK (A51222)
2016 VOLVO VHD...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
