eBay/Craigslist Cub 3000 series front quick hitch -New!! on ebay
   / Cub 3000 series front quick hitch -New!! on ebay #1
ducati996
Banned
New York
jd4100, Cub Cadet 3204 & Cub 125
For those who have the 3000 series Cub. A new hitch is selling on ebay for a great price....all you need is the blower or blade
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=4346783683&ssPageName=STRK:MEWA:IT
Cub3000 quick hitch
Description
BRAND NEW CUB CADET HYDRAULIC FRONT HITCH ATTACHMENT FOR 3000 SERIES CUB CADET LAWN TRACTORS.MODEL NUMBER 343.STILL IN THE ORIGINAL BOX,SELLS FOR $800.00 NEW AT YOUR LOCAL CUB CADET DEALER. COMES COMPLETE WITH EVERYTHING YOU NEED TO INTALL THE FRONT HITCH,COMES WITH HYDRAULIC LIFT CYLINDER, AND HOSE ASSEMBLY,CONTROL VALVE,HYDRAULIC LINES,COUPLINGS,FITTING BULKHEAD-FOR USE WITH TRACTORS HAVING WELDED RUNNING BOARD BRACKETS,LIFT TUBE DOWN,LIFT TUBE UP,HOSE SUPPORT ROD,NYLON FLANGE BEARING,HANDLE,AUX.VALVE #1,LIFT LINK,HANDLE CLAMP,LIFT VALVE BRACKET,HYDRO RETURN TUBE,AUX VALVE #1,HYDRAULIC VALVE ASSEMBLY,,VALVE ADAPTER,DOUBLE VALVE CLAMP,FITTING BULKHEAD FOR USE WITH TRACTORS HAVING BOLT UP RUNNING BOARD BRACKETS.SHIPPING WEIGHT IS 125 LBS.SHIPPING COST TO THE LOWER 48 STATES IS $60.00
<img src=http://i12.ebayimg.com/03/i/03/1a/0d/7a_1_b.JPG>
   / Cub 3000 series front quick hitch -New!! on ebay #2
Did I read this right in that it gives you the same two hydraulic controls like on the JD 318? If not is there a different kit that you need to buy to add the extra ram?
</font><font color="blue" class="small">( Did I read this right in that it gives you the same two hydraulic controls like on the JD 318? If not is there a different kit that you need to buy to add the extra ram?
Thanks )</font>
yes you read it correctly....the front hitch comes with two outlets for the front blower (up /down) you would need the extra outlet and cylinder put on the hitch for a blade (left/right)
The hitch is a quick attach format. The front blower just slides into place (drive up to blower), connect driveshaft via coupler and your done.
Ducati
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
Case 580D (A47384)
Case 580D (A47384)
KMC 3360 4-row Basket Dump Peanut Combine (A52128)
KMC 3360 4-row...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
UNUSED JCT SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED JCT SKID...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
