Cub 2542 PTO Problem
   / Cub 2542 PTO Problem #1
vtsnowplow
I have a 06 Cub 2542 with a problem. I pull out the PTO lever and the blade do not engage. It sounds like the pto in engaging, but the blades are not moving and hense the grass is not getting cut. Do I need a new Belt for the deck? PTO? any help would be appreciated.
Nick
   / Cub 2542 PTO Problem #2
There is not many things that can be wrong. Check the belt to make sure its not broken, make sure it is routed around all the pulleys correctly, and you can check to see if the tension pulley is moving when you work the lever to start the blades. Since you didnt mention any smoke or noise then its probably not a seized spindle.
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2015 CAT D5K2 LGP (A47477)
2015 CAT D5K2 LGP...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
