cub 2176 reverse mowing?
   / cub 2176 reverse mowing? #1
jray1979
How do I disable the reverse mowing pto Kill on my mower......this is very aggrevating feature.........someone please help. I've look all over the net. By the way this mower is shaft drive if that makes any difference.
   / cub 2176 reverse mowing? #2
Crawl under while you or someone works the reverse pedal. Watch where a paddle on the reverse pedal linkage presses against a button switch when the reverse pedal is pressed. #1 you can reposition the paddle such that it can't make contact with the swich. #2 disconnect the electrical connector to the switch and jumper the connector. Of course keep the kids and pets in the house when you mow with these safety features bypassed!! Set it back to normal if someone else uses the mower! (yeah right.. I'm Mr.Safety)
Joel
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2015 CATERPILLAR D9T CRAWELR DOZER (A51242)
2015 CATERPILLAR...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
