Cub 2135 reverse PTO shut-off disable
   / Cub 2135 reverse PTO shut-off disable #1
marburg05
Hello fellow Cub afficianados,
I have a Cub 2135.
I would like to disable the PTO shut-off that happens when you back up the tractor.
Anyone have the easy way to do it?
John
   / Cub 2135 reverse PTO shut-off disable #2
i don't know if your is the same as mine but i tracked down the switch and just ran a jumper from one terminal to the other. it lets the switch thing it's going forwrd all the time. my switch is behind the dash. kind of a pain on mine because you have to remove the gas tank. I think i just traced the wire from the shift lever to the deck switch and jumped it.
   / Cub 2135 reverse PTO shut-off disable #3
Not sure on your model but on most models the switch is activated by a piece of metal that makes contact with the reverse petal. All that is needed to be done is bend the piece of metal back so it doesn't come into contact with the reverse petal shaft. Start looking for the switch just inside the tractor frame it will be along the reverse petal shaft.
q man
   / Cub 2135 reverse PTO shut-off disable #4
HI!It is a grey button type switch located behind the steering on the left hand side,or go under the tractor on left hand side where the foot rest is. just pull the plug and connect the wires together to close!
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
2015 Skyjack SJ 4626 Scissor Lift (A53117)
2015 Skyjack SJ...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
