Cub 1641 pto won't disengage
   / Cub 1641 pto won't disengage #1
OTTO J
Somonauk IL
I just picked this up locally has 900 hrs. When you start it the blades are turning. The pto switch makes noise when you try to flip it but doesn't turn off blades. I unplugged the switch and it won't start unplugged, no power won't turn over. So is the switch bad? Not familiar with these as I've always had green ones til now.
   / Cub 1641 pto won't disengage #2
Since yours will start with the PTO engaged, it is a high probability the usual switch failure occurred and the previous owner FUBARed the switch in an attempt to keep it going.
No experience with the 1641, but you'll need a wiring schematic. Some CCs have an interlock on the seat, reverse and the ignition all going through the PTO switch. If you want to preserve all the interlocks, sometimes buying all new switches is the way to do it. Be prepared for sticker shock.
Rewiring the entire tractor is an option, but not everyone is able to or comfortable re-engineering the electricals.
jack vines
   / Cub 1641 pto won't disengage #3
I have a 1641. Haven't had this problem but the first thing I would do is pull the electric PTO off and inspect and clean it. There is a single bolt on the end of the crankshaft which secures the PTO so it is easy to remove. This unit doesn't have any interlocks that I can think off. My RZT50 is loaded with pain in the rear interlocks.
   / Cub 1641 pto won't disengage #4
Otto J - Most likely, the idler bearing inside the PTO clutch assy is either dragging or is seized up, not allowing the clutch assy to freewheel when disengaged. This failure is not uncommon on high hour machines.
Depending on the make/model of the clutch, you may be able to replace just the bearing and save some serious $$... Would use a camera and take notes before/during/after repair to keep track of detail - and do keep in mind that the clutch assy is HEAVY when it comes off that engine crankshaft.
2020 KUBOTA RTV...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
Kohler Diesel Generator (A47384)
Kohler Diesel...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
