cub 109 hydrostatic transmission troubles
   / cub 109 hydrostatic transmission troubles #1
hawkeye85
wi.
cub cadet 109
my tractor wants to lug forward in neutral and lug the motor down or kill it when its idled down. is it the damper springs underneith the left side of the seat or linkage or internal problems, bearing?tires move freely jacked up motor off. trunnion plate moves freely back in forth which is the part that moves the transmission forward or backwards,motor off. thanks alot
im going to respond to my own question,maybe it will help somebody along the way to to to solving of this problem,just have a little bit for u.there a slot on the plate in which that the damper springs sit in,the parts consist of springs with slugs with stems attached to them on each side of the end of the springs which the slugs are really called the heavy damper and light damper,theres 2 ,where the dampers set inside the plate they've worn out edges of the plate which in turn along with some other worn out parts related to the forward and backward control which causes the tractor or transmission to want to creep forward or backwards ill keep anyone who had enough patience to read this informed how this project pans out. this maybe more clear to someone who is experiencing the same kind of problem
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Westfield MK130-91 Swing Away Auger (A50514)
Westfield MK130-91...
1995 Case IH 2144 Combine (A50514)
1995 Case IH 2144...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
