Cub 1040 won't go forward or reverse
   / Cub 1040 won't go forward or reverse #1
KBM80J
Topeka
Cub Cadet 1040
Mowing yesterday on a slight incline and it felt like the pedal disengauged and went to the floor. The mower slowly started down the incline, brakes worked fine and the mower continued to run. I haven't had a chance to remove the deck to check but thought I felt some sort of belt going from the back (transmission) to the front. Is there such a belt and if so, can I replace it myself. THought this was a good place to start. Thanks
   / Cub 1040 won't go forward or reverse #2
Yes. There is typically a belt running from the engine to the rear on most mowers. Could be rather rough getting one back on however. If I remember correctly on my fathers 10 year old jd mower he had to remove the steering column or some other semipermanent piece. Good luck. Hope it's easier on the cub.
   / Cub 1040 won't go forward or reverse #3
I had a ~2008yr LT1042 that did that - there is a tension spring that goes to a pulley that the drive belt goes past. If the belt looks good check for the spring. Mine broke. Couple of $ for a new spring and 10 minutes (probably 8 minutes figuring out where the spring actually went) and I was set.
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
