CT445 and the Kirkland 12877 battery
   / CT445 and the Kirkland 12877 battery #1
ttriff
8400' Colo high mountain plains
Bobcat CT445HST
Was going to top off the firewood supply for the house. Headed out to get 'Bob' (yep it's corny but that's what everyone calls it). Bob had very dim indicator lights and a clicking noise instead of the starter motor turning
Grabbed the DMM, the battery read 10.7V, so oops, an open cell ...... no joy.
Pulled the stock battery and of course no info except a Bobcat Part number and a Group 24 indicator.
Decided to take a look around Costco's battery rack. They had no group 24 batteries, but had a group 34, 795 CCA for $84. A quick Google search showed Group 34 had the same footprint as group 24, but the group 34 batteries were 1" taller.
Given the looks of the CT445 battery compartment it didn't appear the 1" additional height would be a problem, and sure enough it wasn't. The new battery dropped right in.
Bob roared to life and things are good. Now we'll see how the battery holds up in real world use....
I imagine this same battery will fit the 440,and 450 as well, don't know about the smaller framed Bobcat CUTs.
   / CT445 and the Kirkland 12877 battery #2
I took the OEM battery out of my Kioti after about a year since it was not cranking very well. Put in a nondescript Costco battery and it has been cranking like a champ for the last three years. I neglected to turn in the old battery and my son grabbed it and has used it in his Dodge van for the last year or two with no problems. These tractors must be a lot harder on batteries than cars are.
   / CT445 and the Kirkland 12877 battery #3
Know the feeling. Had to put a new battery in my CT450 yesterday. $109.00 for a group 24 battery from my local Ransome/Cat dealer. It was about $25.00 more than I wanted to spend, but I did get to talk to their service tech about my out of level loader and also about how to install a block warmer. With any luck, his advise was worth the $25.00!
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
JOHN DEERE 8245R LOT NUMBER 260 (A53084)
JOHN DEERE 8245R...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
