CT335
   / CT335 #1
SABULA FARMER
Pennsylvania
Bobcat CT335SST
Was wondering if anyone else has noticed the hydraulic level not reading on the dip stick...?
I can pull the dip stick and it won't show a level, put it back in and pull it out and it's at the full mark?? What's the deal???
   / CT335 #2
Me too, but I've noticed that if you look at the other side of the stick (back side) you can usually get a level indication. For some reason, one side isn't always there. It must be the angle at which the stick goes into the tank. :confused2:
   / CT335
I will have to look at that the next time I check it. I think it was not on either side of it, but I cant say for sure...?
   / CT335 #4
When you pull the stick out, hold the stick in the horzontal position and you will be able to see it better!
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2000 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A51242)
2000 BOMAG...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
