CT335 tractor help
   / CT335 tractor help #1
John White
Newark, Oh
Bob Cat Ct335
Have a ct335. I understand that there are 4 relays under the dash. How do you go about removing dash to get to them. From a little info. I have it says picture 290. I don't have a manual. My tach, or warning lights do not work. Fuse 3rd from bottom has no power feed to it. (Red wire, blue stripe) Trying to find out which relay feeds it.
   / CT335 tractor help #2
Hello, on my ct445 the relay that caused the same issue was on the firewall side, under the hood.
Had to remove dash. It has 5 relays under there. I back fed the fuse block till I found the right one and replaced it.
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
