CT332 slow track speed one side
   / CT332 slow track speed one side #1
Gilejack
Sutherlin, Oregon
John Deere ct332
hello new here. I have a JD ct332 with a track that's slow going forward and works fine backwards. If you raise the engine speed the track will move faster.But not as fast as the right side, forward & backwards right side works normally which makes for a interesting ride. has a lot of hours so We replaced the drive motor. relief valve stuck, low pressure where would I put a pressure gauge and what should I see any help would be app.
   / CT332 slow track speed one side #2
In the general sense of things, you can tee after a pump and before the first valve, and read the pressure for any hyd action.
You probably have more than one pump.
You probably want to use a 5000 psi hyd valve.
yes 2 sections swashplate style and a charge pump it acts like a valve not stroking all the way or a leak in the servo
   / CT332 slow track speed one side #5
You need to get that hydrostat pump out and check out the corresponding pump section that matches the drive motor you replaced
When you changed the drive motor, did you open it up and find damage?.....they share the same oil in a continuous loop so damage from one component shares the contamination with the other, which in turn damages the shared piston pump section
Sterling 9500 (A55301)
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A52705)
2016 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
UNUSED RAYTREE RMVR76 - 76" HYD VIBRATORY ROLLER (A54757)
UNUSED RAYTREE...
