CT235 mid leak
/ CT235 mid leak #1
catdozer
Platinum Member
john deere
On my 235, I have a leak coming from the center of the machine that after further inspection looks like it's coming from the inspection hole (about 2inches round) also it looks as if it's weeping from the top,(need to take seat off for better inspection) wondering if you guys/gals have seen this? Looks like some have said need to split the machine in 2 for a o-ring?
It actually seems to leak the most when parked. When running I don't think it drips as much.
/ CT235 mid leak #2
I have a similar leak. I actually have two. One on the hydo shifter. Not able to cure after several tries. I also have a small leak where the rear shaft goes in the central housing. I am learning to live with the second one. Looks like $600 to $1000 repair.
/ CT235 mid leak #3
I have a CT235 and the only problem I have had with it, is the bolts between the transmission and rear end loosen up and allow it to leak underneath. I have tightened the bolts (about a 3/8 in. bolt) twice in 4 years. When I get time I'm going to clean the area and Loctite the bolts. When tightened up I have no leak. JP
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
John Deere XUV825E (A61306)
John Deere XUV825E...
2014 Audi Q7 AWD SUV (A59231)
2014 Audi Q7 AWD...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
