CT235 Battery
/ CT235 Battery #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
Battery has decided to start leaking on my 2011 model. Anyone replace with a non bobcat brand, if so what?
/ CT235 Battery #2
I have a Kioti, changed mine with standard HD auto batt fron Canadian Tire. I am sure any brand would do. Also changed batt terminal clamps to match N/A post sizes as OEM ones seemed to glaze over causing problems, (high resistance contact).
/ CT235 Battery #3
The original battery is Group 24 / 600 CCA (cold cranking amp). Group size is universal for battery industry, any group 24 battery will fit in the box. Should stay with minimum 600 CCA but higher Amp rating doesn't hurt, just costs more. From there you have decision of going with normal maintenance, low maintenance, or maintenance free styles.
/ CT235 Battery #4
Got one at Costco, much better than OEM.
/ CT235 Battery #5
I used Walmart. Much better than the OEM acid leaker
/ CT235 Battery #6
As this seems to be a common issue, has anyone measured the voltage across the alterantor as a possible culprit for overcharging?
A great replacement is an AGM glassmat dry cell but expensive.
/ CT235 Battery
talked to the dealer there are no known issues, as always right, he said what lockport mentioned above which was to bring it in and make sure the alternator is not bad. Fine by me if there were not so many folks with a bad battery....
/ CT235 Battery #8
I had a battery issue recently on my ct122. A leak turned my terminals black and corroded the terminal ends. Dealer replaced both the positive cable and the battery under warranty.
/ CT235 Battery #9
I used the sears sealed battery. My original battery leaked and made a mess.
2024 JCB 35Z (A60462)
UNUSED INDUSTRIAS AMERICA EASY MAN TREE & POST (A60432)
UNUSED INDUSTRIAS...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
2020 CATERPILLAR 246D3 SKID STEER (A60429)
2020 CATERPILLAR...
