CT 235 seat switch
   / CT 235 seat switch #1
lilranch2001
Super Member
Bobcat CT 235
Ok , I was just putting the seat up because I wasn’t putting the tractor away tonight as the rain started and somehow the wire got caught and the switch got yanked out of the seat. Nothing really appears terribly damaged but I can’t figure out how that switch was actually afixed inside the seat.
There is a minor plastic damage to the actual switch.
I’m assuming that switch is switching the negative in the safety system? Am I correct in assuming that? I was going to get the meter out and check it to see if it had a reading between that wire and the ground system but it’s raining pretty hard right now.
I would prefer not to cut the wires to and tie them together to bypass the switch. I’d rather leave the electrical system intact if I can, but I doubt I can find it new switch from Bobcat.
Does anybody have a good trick to use something as a jumper across the two terminals inside the connector? If it’s not going to sort out electrically to the ground, then I’m probably good with just using a piece of 12 to wire but I didn’t know for sure as I’m sitting here thinking about it if it’s a hotwire.
Does anybody have a part number for that switch?
Thanks in advance for any help that you can give me
Thanks Winston, that appears to be identical!
$67 for a elecheapo switch, crazy!
I will probably by pass it as well
2019 CHEVROLET SILVERADO 1500 TRUCK (A50459)
2019 CHEVROLET...
2022 CATERPILLAR 299D3 XE SKID STEER (A50458)
2022 CATERPILLAR...
Hot Stick 12ft Trailer (A48837)
Hot Stick 12ft...
2012 VOLVO A40F OFF ROAD DUMP (A50458)
2012 VOLVO A40F...
(1) 14ft Tarter Gate (A48837)
(1) 14ft Tarter...
Two Seater Pontoon (A48837)
Two Seater Pontoon...
