powerscol
Veteran Member
New twist today for my CT 235
After solving the water in fuel issue now this.
Weather has been warm this week here in CO, about 50 today, so decided to clean out horse paddock running mid RPM no issue - tractor worked like a charm great power and loader response. This took about and hour. The went to do a bit of pasture work and to run around I raised the RPM to near max - noticed a puff of smoke once in a while, but it got worse over time. When putting it back in the barn I sat level and ran it to full PTO rpm and got more blue smoke and rough running like a misfiring spark plug.
Called dealer - he had me check oil level - which was about 3/4 inch above full mark. HYD oil is at full mark. Wants me to drain oil to full mark (he estimates it to be 1 QT high) and run a while and see if it clears up, also wants me to watch oil level . (will do that tomorrow). Oil smells and looks normal.
He thinks I may be getting fuel into oil (over fueling). Does not seem right only being 1 hour from having the 50 hour service done. Also over fueling should produce black smoke not blue - correct? My bad for not checking level after the service or before starting today, but he says they triple check fluid levels before it leaves them.
Question - could high oil level cause this - I know it will in my gas riding lawn mower. Is there a simple way to check for fuel in the oil I drain?
I also looked at the fuel filter again for water (did not pull it though). No water present that I could see. Could I still have a water issue that could cause this? Ran fine for over and hour. Just wondering
Thanks everyone.
Thanks everyone.
