CT-235 1st small problem
   / CT-235 1st small problem #1
rossgtn
Near Chattanooga, Tn
Bobcat CT235
Just wondering if anyone else has run into this problem. I developed a fuel leak. It appears that the hood had either rubbed or pinched a hole in one of the two small fuel lines coming from (or going to) the top of the fuel tank on the right-side. I'm guessing this is some form of return line but am not sure. I haven't contacted my dealer yet but plan to do so later today. Looks like there is just not enough clearance between the hood brace and the hose. So, if you are needing to open your hood a lot and start seeing fluid, check those lines.
   / CT-235 1st small problem #2
I have a CT235 with 60 hrs. Just checked my lines after reading your post. No signs of rubbing or chaffing on either of the two hoses.
   / CT-235 1st small problem #3
09 ct 235 with 185 hrs. and is in the shop now for a hyd. problem,but I,m sure it,s an easy fix.No other problems.Great tractor,very easy on fuel and plenty of power.I think it could just about work side by side of a I.H. M we once had:thumbsup:Dave
John Deere 6400 (A50121)
John Deere 6400...
1996 International Bucket Truck (A50323)
1996 International...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
4 wheeler (A50121)
4 wheeler (A50121)
Electric Mobility Scooter (A51694)
Electric Mobility...
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
