Crusise Control Issues 4520
   / Crusise Control Issues 4520 #1
ham
Hey folks I am in haying season and my standard JD 4520 cruise control won't kick in. Click the button and nada. Gave the dealer a call but of course it was late Friday so no solutions yet. I put my voltmeter to the wires behind the switch and no power is noted. So do any of you know which fuse they run these through? I haven't noticed anything else not working. I don't have a radio. Of course the manual doesn't show the cruise control on the fuse page...I can't remember but I think it is an added on option. I don't see any addtional fuses not noted on the manual on the board. Nothing lights up on the dash either. So any solutions?
   / Crusise Control Issues 4520 #2
Did you measure the voltage from ground to each contact? Or did you read across the switch contacts? I would guess you need to measure from ground to the contacts to get a proper reading.
I would also pump the reverse and brake pedals a few times to make sure you don't have a sticky pedal switch too.
Maybe EE Pete a member here will see your thread and comment.
Well still no answers. Anyone here with a 4520 know which fuse they used?
I think I used the voltmeter correctly. The main point is it doesn't work at all. And the dealership seems a bit slow at finding a solution. I just thought maybe somebody had run into a similar issue.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
