Crushed Concrete for driveway
   / Crushed Concrete for driveway #1
japody
Platinum Member
Richmond & Boydton VA
Ford 4000 & 5000, New Holland TN65, Mahindrda 2516
Has anyone used crushed concrete for their driveway? I've got a contractor telling me it works as well as 57s. It's $300 for a 15 ton load vs. $500 for the 57s. I'll need at least 12 loads. He's doing a major overhaul including using a road grader to get down to hard pan, vibratory sheepsfoot roller, ditches and piping. The concrete will be used as the base and rolled. Will come back later with crush and run for top coating. Thanks in advance for any input.
   / Crushed Concrete for driveway #2
I really like the stuff, it's $31.00 per yard here...
The big deal about it here is, to get some that "doesn't" have a lot of metal in it...
SR
   / Crushed Concrete for driveway #3
Neighbor used it for base on his driveway, hasn't yet put top on it. It did have some steel in it, he spent some time picking it out as his contractor delivered and spread it. Course enough to require a dozer to spread effectively, about 1.5" +/-. Time will tell how well it works, our soil gets pretty gooey during the winter and requires a good base to make a driveway that will hold up over time.
   / Crushed Concrete for driveway #4
So is this the same as "concrete screenings" or larger, more gravel sized? I've used screenings for a base as it is fine and packs well. No metal here that I recall.
   / Crushed Concrete for driveway #5
You can get recycled material around here. It’s not as pretty and some engineers won’t spec it. So if you like the look and don’t mind it possibly not meeting a specific spec - make it happen.
   / Crushed Concrete for driveway #6
Crushed concrete will usually deteriorate and breakdown if left exposed to weather in Ohio
   / Crushed Concrete for driveway #7
We did a section of drive with it this year. I paid $370 per 18yd truck load. Pleased so far. It needs raking again with all the rain we've had but it seems to be holding up well. One of the county road guys talked me into using it. He says it has a compaction rate that is 20 times greater than limestone.
The stuff I got was clean white crush no larger than 3/4". No steel that I've seen.
   / Crushed Concrete for driveway #8
... The big deal about it here is, to get some that "doesn't" have a lot of metal in it ... SR
I love CC, spread in bucket-loads vs just pushing from a pile which would leave too many fines where it was dumped.
Also use a 30" 'magnetic floor sweeper' (HFT, Amazon) to remove rusty iron and scraps of cyclone fence 'remesh'. Go over the job again later on to be sure. (pull it, not push it)
Same as with cru$hed lime$tone I regularly get 'right sized' rocks sticking between the lugs on golf cart tires and they end up in the garage. :rolleyes: Edge tamers (3) let me use the FEL bucket to move snow (550' d-way) and keep me from plowing gravel into virtual curbs. t o g
   / Crushed Concrete for driveway #9
For a base I think it's great. With crusher run over the top, you'll never know the difference.
   / Crushed Concrete for driveway #10
Here in East Texas, limestone is the only choice for road base. It's crushed with jagged edges ranging in size from an inch and a half or so for the very largest rocks, on down to fines. It works really good, but does break down over time. My supplier recommended crushed concrete instead of limestone. He said that it's harder, it doesn't break down and it compacts a lot better. I took a chance and gave it a try. He was right, and that's all I will buy now. There is a significant difference, especially after a heavy rain where the limestone feels a little wet and snotty, the crushed concrete feels solid.
Crushed concrete is not the same as concrete wash. The wash is what's left over in the cement truck and full of river rock that will never compact. The crushed concrete has rough edges and it's mixed in size all the way down to fines, so it compacts really good and gives you a very solid surface. I don't add anything to it, just get it four inches thick or more, and it works great!!!
Baldor TS80 81kVA 3-Phase Towable Diesel Generator (A42742)
Baldor TS80 81kVA...
PALLET OF PICKS; PRY BARS; T-TOOLS (A45333)
PALLET OF PICKS...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
YANMAR SV08-1D (A45333)
YANMAR SV08-1D...
2004 Hyundai XG350 Sedan (A42744)
2004 Hyundai XG350...
1999 Volvo VN Truck, VIN # 4VA7BBJF5XN759815 (A44391)
1999 Volvo VN...
