cruise control boot cracked
   / cruise control boot cracked #1
farmacist
Bronze Member
Saranac, New York
TC35D
TC35D et al. If you are still under warrantee check the rubber boot on the cruise control switch which pushes up against the right brake pedal shaft. When you are under there also check the boot on the emergency brake switch. My rubber boot on the cruise control switch, at 18 months and 165hrs, is cracked and deformed. I will get a new switch under warrantee before water gets in there.
This is only my second small problem but the price is right. Frank
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
Magnum 4000 Series Hot Water Pressure Washer (A47384)
Magnum 4000 Series...
Vicon RV1601 Round Baler (A50774)
Vicon RV1601 Round...
