I'm going to set up a loader mounted snow plow for winter - got the donor parts from an older Fisher 6.5 foot that's been sitting around for a while now. I'm wondering about the hydraulics though...
I was going to set this up on my last tractor and make something similar to the Deere 366 front blade, and when I studied the parts diagrams it uses a crossover relief valve between two single-acting cylinders and quick couplers to the the tractor hydraulics.
Looking at the AF11 loader mounted snow plow, it is just showing two single acting cylinders with hoses straight to quick couplers to connect to the tractor.
The question is what do I need for mine? I'm running a 3039R with a 3rd function controlled from the joystick thumb button to run the blade angle. I'm assuming that the loader mounted style is assumed to be run off the 3rd function and does that already have a relief valve in the system so it doesn't need an additional one.? The 366 front blade came about when loader mounted attachments weren't as common and electric 3rd functions were not around. Is that why it is needed in that system?
