Crossbow herbicide Vs. Rural King "Crossroad" herbicide
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Crossbow herbicide is very difficult to find in north/central Florida.
The Rural King in Gainesville, Florida regularly inventories Agri Star "Crossroad" herbicide:
2,4-D -----------------34.4%
Triclopyr BEE---------16.5%
Inert Ingredients-----49.1%
Similar? Better? Worse?......than Crossbow?
Crossbow is the only herbicide which killed spreading native Florida Blackberries in one application for me, in part of an ornamental, non-grazed pasture. I applied Crossbow with a one-gallon sprayer.
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #2
The Rural King in Gainesville, Florida sells Agri Star "Crossroad" herbicide:
2,4-D -------------------34.4%
Triclopyr BEE----------16.5%
Identical active ingredients (and less expensive):
From Crossbow label: http://www.cdms.net/ldat/ld02h006.pdf
Steve
Thank you, Steve, for your definitive responce.
I have been buying Rural King Crossroad herbicide when in Gainesville, Florida, 40 miles from home.
The last two visits, about two weeks apart, Rural King was totally out-of-stock on Crossroad.
Today I was in my local Tractor Supply store and chanced to read the label on:
GORDON'S BRUSH KILLER
One Gallon - Makes up to 64 gallons of spray solution.
I use 3 ounces per gallon of water = 42.6 gallons of spray solution.
Triclopyr~~~~7.81%
2,4-D~~~~~16.49%
Dicamba ~~~1.38%
Inert~~~~~73.2%
One gallon concentrate $49.99.
I have found this Gordon's herbicide ALMOST as effective as Crossbow and Crossroad. I have not sprayed GBK on Florida pasture blackberries, but I will.
Any illuminating comments on Dicamba, which I am not familiar with?
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #5
I ran into the same issue finding Crossroad herbicide last year. I don't use a lot of it, but when I need it most so does everyone else and the shelves are bare for months. I bought a few gallons last winter when they had plenty at RK. I use it mainly for Multiflora Rose, berries, and poison ivy. I also use for black locust occasionally, but that's an uphill battle. I even used Crossroad in a boom sprayer on an area of lawn that was choked out by ivy and difficult weeds. I think that Gordon's product would work for me, and I use some of their other products including Trimec, but I'm comfortable getting just the right mix using Crossroads so it's tough to change.
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #6
I googled "Dimethylamine dicamba" and got quiet a lot. It is basically a broad leaf specific herbicide.
The results also provided a link to the National Pesticide Information Center where a technical fact sheet can be found.
Hope this helps.
   / Crossbow herbicide Vs. Rural King "Crossroad" herbicide #7
all of the RK herbicides I have used have done just as well as the "name brand" But, 2.5 gal of crossroad is $99.
2.5 gal of gly (imitator) is $35. 2.5 gal of 24d Amine is $30. $65 for the 2. 2oz of each per gal to me has done almost as well as the crossbow did. If its something really woody I will add some triclopyr to the mix.
2004 STERLING  L9500 MIXER (A45046)
2004 STERLING...
Electronics Storage Cabinets (A44391)
Electronics...
2014 KENWORTH T800 (A45046)
2014 KENWORTH T800...
Toyota 42-6FG25 5,000 lbs Warehouse Forklift with 3-Stage Mast & Side Shifter (A44789)
Toyota 42-6FG25...
ATTENTION PLEASE READ (A44502)
ATTENTION PLEASE...
2016 Ford F-250 Utility Truck (Diesel), VIN # 1FT7X2AT9GED35737 (A44391)
2016 Ford F-250...
