Alright, so this isn't exactly a tractor issue, but it's pretty close... Yesterday I drug out my JD D130 mower and was doing the spring maintenance routine. While greasing, I once again had trouble greasing the front axle pivot zerk. Every time I grease, this one always gives me trouble. Decided to tinker with it and realized that the grease wasn't actually flowing out around it; the zerk itself is fine. It's actually coming out from behind after passing through it, as it is cross-threaded. I thought it odd that it was angled as it was... Mystery solved. This is how I got it from the factory, btw. JD QC strikes again. So how do I go about rectifying this? Should I drill it out and tap it for a bigger zerk? Not sure how I'd do so without forcing metal shavings into the cavity...
Any advice or ideas would be much appreciated!
