Oil & Fuel Cross reference
   / Cross reference #1
Spin88
Benson
LS XR3135H
Are the filters (inner, outer, fuel, oil, HST) available after market yet for LS XR3135H?
I used the LS filter chart to find my part #s but can't cross it to find locally. Closest I came was Napa that says my oil filter exists but they don't have it.
   / Cross reference #2
Wix crosses only 3 filters, fuel, air, and hydraulic. Nothing for the oil or HST yet.
WIX Filters - Products Catalog by Application
Hyd - 51517 = NAPA 1517
Air - 46438 & 42985
Fuel - WF8395
Not sure how accurate this cross reference is. Maybe another 3135 owner will reply. NAPA 1517 shows a cartridge type filter and not a spin on type.
   / Cross reference
Thanks George. Oil has been the problem the whole time. Looking at the filter makes me think it's out there, but elusive.
   / Cross reference #4
What is the factory part number for the oil filter on a 3135?
EDIT - I found it #40318591 and don't see a cross yet.
It took a couple years before I could cross mine.
Air, HST and Hyd. filters are the same between the 3037 and 3135 but fuel and oil are different due to different engines.
   / Cross reference
I actually found it to be 40006986. That was from LS site.
   / Cross reference #6
My mistake, you are correct. I grabbed the wrong number from the chart I have.
  • LS FIlter Chart.pdf
   / Cross reference #7
I found this in the filter post. The 4150 uses the same filters as your 3135. Check this link. Send a PM to the last poster to see if he's actually used the filters he posted.
http://www.tractorbynet.com/forums/ls-tractor-owning-operating/192544-ls-tractor-oil-gas-air.html
"A little update on realhunters post since RCO doesn't put the actual filter numbers on their invoice. They substitute baldwin filters for everything the y can. I have a 2016 LS XR4150HC so here is the list I have of filters which also includes the HST filter:"
Hydraulic filter: Baldwin bt839-10 or wix 51551MP
Oil filter: Baldwin B243 or wix 51516 or 51516XP
HST Filter: No Baldwin match, Wix 51715
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2021 Liebherr L556 (A52128)
2021 Liebherr L556...
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
KMC 436 Peanut Inverter (A52128)
KMC 436 Peanut...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
