Cross port checks need upstream ported to tank
   / Cross port checks need upstream ported to tank #1
EE_Bota
Veteran Member
North Carolina
Kubota BX2200
I am not a hydraulic expert. But I am what passes for one in our factory. For some reason, the mechanical folks leave the hydraulics to the electrical folks, and the electrical folks are lead by me.
We have many diverse hydraulic systems, and often there is a cross-port check valve. I have noticed over the years that some of the cross-port check assemblies do not work well. I have tended to assume that it is because of a leak in the piston seal of the cylinder. But that is not an easy assumption to make.
For one, if the rod seal is not leaking, even if the piston seal is gone, the cylinder simply reverts to a simple ram, and the effective area of the newly created ram is equal to the diameter of the rod, not the piston. Therefore, although the line pressure required to hold the load is greatly increased, the load still should not move, provided rod extension is opposing the load, not rod retraction.
What I am instead concluding it that cross-port checks are unreliable if the controlling valve blocks ports A and B instead of porting them to tank. This is true even if P is ported to tank.
Knowing this may effect some of the top and tilt cylinder purchasing decisions.
Blocking A and B may not render all cross-port checks useless in all instances, but will make many useless.
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
Pallet of miscellaneous chains  (A52384)
Pallet of...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
