Cross Over or DRV adjustment
   / Cross Over or DRV adjustment #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
I have a snow plow with a 2 hydraulic cylinder angle adjustment. I installed a cross over relief valve and would like to “properly” adjust the relief valve. Is their a way to do this with just Tractor hydraulic pressure? I know I can push one side against a rock and adjust the relief by “feel”. But I was wondering what the “book” answer is. I can’t find much on YT or with a google search.... but maybe I’m searching for the wrong thing. It’s a Prince valve but I didn’t find much on the Prince sight.
   / Cross Over or DRV adjustment #2
I don't know of any way to adjust them just using your hydraulics.
You could put pressure on one side with a gauge and adjust to relief at a set pressure.
What I have done is back the adjuster off most of the way and use the blade if it was nuisance tripping,
tightnen the adjuster till it was functioning as desired.
   / Cross Over or DRV adjustment #3
I put this one on my plow
1/2 NPT 3 GPM 15-3 PSI Hydraulic Cushion Valve | Relief & Cushion Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
It has a range of 1500 to 3000 psi. From the research I did I couldn't find mush on how Fisher set their's but found one place in forum where a guy said 1400 psi. My angle cylinders are good for 3000 psi. I figured I'd shoot for 2000. I counted the revolutions on the adjusting screw to see how many psi per turn. Cranked all the way in and called it 3000 psi then backed off to 2000. No idea what it really is but it works fine. Plow pushes hard but relieves when it comes up against something solid.
gg
Ok that’s good info from both of you! I should be able to back off the relief valve, dead head one side of the relief valve into my gauge and increase the relief valve until I get to between 1400-2000psi right? My tractor’s main relief is set at something like 2400psi.
2017 Ford Fusion SE Sedan (A48082)
2017 Ford Fusion...
2022 Argo Xplorer XRT 570 LE 4x4 ATV (A48082)
2022 Argo Xplorer...
1992 Effer 7600 2S Knuckleboom (A49346)
1992 Effer 7600 2S...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2014 CAT 740B Articulated Dump truck (A50490)
2014 CAT 740B...
