Creeper Gear ?
   / Creeper Gear ? #1
ttstraw
Coudersport, PA
Ok folks, my Dad and I can not figure this one out so I need some help. Looking through a Tractor Auction mag we noticed an add for Case (I believe) talking about their transmissions. They stated that theirs would do 60' per hour. My Dad and I were trying to figure out what you do at 60' per hour or when would you need a gear that slow! Ideas??
   / Creeper Gear ? #2
That's crazy, it's a foot per minute or 2 "s in 10 seconds, I was gonna say maybe the space shuttle to the launch pad but that probably moves faster than that. You wouldn't even know it if you got off the machine with it in gear, it would be barely moving, you could go in the house for some coffee and when you came out it would only be a few feet away from where you left it!!!
   / Creeper Gear ? #3
Creeper gears that slow are usually for use with a trenching attachment.
Sincerely, Dirt
   / Creeper Gear ?
A trencher is was I was thinking but most of those that I know and have seen were dozers used to bury fiber optic cable and this was a wheeled tractor. It was a big joker too, one of those with duals in the front and back with center pivot in the 300-400hp range.
   / Creeper Gear ? #5
May have been used to pull a tiling machine, similiar to cable layer, but is used to lay field drainage tile.
   / Creeper Gear ? #6
MY Dad use to talk about a F-20 Farmall. He said in the late winter when they were plowing to get ready to plant potatoes they would get the tractor wheels in the furrow and then get off and walk beside the tractor to keep warm. But I never heard of a tractor this slow.
Don
   / Creeper Gear ? #7
My idea is also a trnecher or tiller tranny. I've seen them for fords that have some amazing gear ratio's.. like 90:1.. etc..
soundguy
   / Creeper Gear ? #8
Here are a few uses of a creeper gear...:D
Tobacco farmers need a creeper for The Kirpy harvester ground speeds
Vegetables Farmers
Vegetables are grown on six foot beds and are usually planted in three rows. This allows as much mechanical weeding as possible, minimizing expensive hand weeding. A combination of a sweep hoe (L-blades and A-blades), rotary brush hoe, and flame weeder are used depending on ground conditions and the stage of plant growth. Some hand weeding is always necessary and is done using a bed weeder. This piece of equipment is attached to the three point linkage of a tractor fitted with a creeper gear box (extremely slow). It is made up of a wide frame covering three beds of vegetables, and mounted on the frame are nine "stretchers." Nine people then lie on the stretchers that are suspended just above each single row of vegetables. This allows them to weed by hand within the row of vegetables from a position of relative comfort. This is much easier on the human form and is also surprisingly fast. Potatoes are grown in traditional ridges that are progressively built up during the early stages of plant growth which gives good weed control. Potato haulm is topped and burnt off with the flame weeder prior to harvesting in September. Carrots are harvested from August through until November using a top-lifting harvester. A top-lifter pulls the carrots out by the leaves, minimizing damage and leaving the soil behind. Once the first autumn frosts arrive, the carrot tops become weaker and the top-lifter is no longer effective. We then use a combination of the potato harvester and hand lifting to complete the harvest.
Vegetable Farmers also use a creeper from laying out the wrap....
Tractor composter
Brown Bear has introduced a revised model of its farm tractor composter. The PTOPA35C-10.5 unit is designed to be attached to the front of 100-160 hp farm tractors. The composter requires a front 3-point hitch, 1000 RPM PTO, and creeper transmission. It is available for ISO and counter ISO PTO shaft rotation. It is designed to compost biosolids, yard waste, manure and other organics.
Brown Bear Corp.
Corning, IA
Tel: 641-322-4220
Web: homepage
As mentioned tilling requires a creeper
Snow blowing will benefit from a creeper
Nursery operations will use creeper when treating seedlings
   / Creeper Gear ? #9
Golf courses use 'em for certain types of aerators I think they call 'em Verti-drain units that aerate 16 " deep.:cool:
PALLET OF AIR HOSES; AIR HAMMERS; DRILLS (A45333)
PALLET OF AIR...
AGT QNT50R Mini Excavator (A42021)
AGT QNT50R Mini...
2012 Volkswagen Tiguan SUV (A42744)
2012 Volkswagen...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2017 INTERNATIONAL...
2020 Chevrolet Tahoe SUV (A42744)
2020 Chevrolet...
Light Tower (A44571)
