Creating a lawn
   / Creating a lawn #1
MW66
Buffalo, NY
Here's the scoop. We just finished our new home and they have to come back to finish grading this spring/summer. Our property, just where the "lawn" will be is approximately 400' wide by 350' deep up to the wood line. They will finish grade 200' x 350' deep as this was the section where they dozed and stripped the topsoil. The section adjacent (200' x 350') is where I plan to recover the field and make one contiguous lawn that will be 400' x 350' (about 3.5 acres). It is basically flat and once was used for farming. There are a few small scrub brush type plants, but not a lot, and I also planted a 12 tree orchard. My plan is to buy a Kubota B3200 this spring and the dealer told me that a rear tine 54' tiller would make quick work to recover the field in 2 or 3 passes max. Is there any other equipment that I would need to turn this into a suitable state before I spread grass seed? A box blade? Rake? Do I need something like the ratchet rake to rip out the small scrub brush first? I'm not looking for a golf course type lawn, but I would to get it right before I put seed down. I'm going to also buy a heavy duty roller roller, a mower (not sure RFM or MMM), FEL, and snow thrower.
   / Creating a lawn #2
All I can say is you must be a glutton for cutting grass!!! 3.5 acres is alot to cut all at once.
Will you have other uses for the rototiller after you get the lawn established? If not, I would consider getting a used 7 shank chisel plow and run over it back in forth east & west, then go over it again north & south. That rototiller is not going to go very deep anyway, if there are established (small) trees and/or bushes, you probably need to rip up their root systems. After you got all that dirt chewed up, a rake would smooth it over nicely.
   / Creating a lawn #3
I agree that 3.5 acres is more than I would want to mow. That would be 4 to 41/2 hours with my zero turn mower and that gets old doing it once a week.
I think the tiller and a rake would be a great combination. Follow that with a home made drag, log with fencing wrapped around it, pallets chained together, or varies other combinations and you are set to go. I am not sure why you would want to compact the soil with a heavy duty roller after loosening it up to plant. I do use a small light roller to bed seed after using a drag.
You might want to think about a tractor mounted spreader for seed, fertilizer and lime if needed. Your best bet is get a soil test done to see what the soil needs. Seed and fertilizer has gotten too expensive to guess.
MarkV
   / Creating a lawn #4
I think tilling is going to take a little longer than the dealer leads you to believe, at least the experience I have with tillers. Unless the ground is fairly loose already as in plowed. Usually leveling with a dozer leaves the ground fairly firm, the tiller won't bite too well. A heavier tiller will help. To plant grass only the top few inches needs to be loosened, dragging it with a piece of chain link fence works pretty well on loose ground for final leveling. I seeded at half the rate, lightly dragged with the chain link then seeded the other half and rolled with a Brillion seeder borrowed from a nearby farmer with great results. As Mark said a soil test is highly recommended.
   / Creating a lawn #5
One of the more important things to consider with a lawn this size IS making it smooth as a golf course, it will save you time, wear and tear on the equipment and wear and tear on you. What I did was till the entire lawn about seven inches deep then ran a 3pt landplane/grader over it to smooth everything up, seeded the lawn and harrowed over it. I can now cut just over an acre an hour with my small riding mower running full speed. This same lot used to take three or four times longer to mow.
   / Creating a lawn #6
How is your top soil? Mine is better suited to patching ponds than growing grass. I used a double bottomed plow and disk to plant 2 crops of buckwheat prior to putting in the lawn. After the second crop was plowed under, used a plain rear blade (not a box blade) and a homemade drag to prep for grass seed. I mow the 3 acres in just over two hours w 60" RFM then the wife trims with a 44 " rider in 1-2 hours
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
UNUSED MOWER KING SSFFGC175 HD FLAIL MOWER (A51244)
UNUSED MOWER KING...
71050 (A49346)
71050 (A49346)
IH 445 Square Baler (A50515)
IH 445 Square...
