adammsmith
- Joined
- Mar 9, 2009
- Messages
- 11
I posted earlier but seam to have a new problem. (recap) I ran it out of fuel and then replaced the filter. I primed it and it starts up just fine but looses power. Sometime it runs for 30 secs sometime 10 min.
Everytime it looses power, I bleed it at the injector pump and there is air there. I bleed it, the darn thing runs, then dies. I crack the bleed screw and air comes out. I then drained the tank to looked for any type of debris.(nothing) Next I ran a line from the tank directly to the injector pump. It started up then died. I cracked the bleed screw(at the injector pump) and it had air in it. I removed the banjo bolt and removed the copper washers. They were pretty worn. I filed them flat (as close as I can get them) ( they still have a groove). I plan to order new ones tommorow, could this be my problem? I can't see how air can be getting past them. I need your suggestions before I pull the rest of my hair out. thanks, Adam
