Crawl locks up
   / Crawl locks up #1
rmully
North Carolina
YM 2020
While tilling deep to plant potatoes I shifted the transmission into crawl as i was not doing a long run and was wanting to till rean fine. When I was finished I could not get the crawl pop up to release and was locked in that position for quite awhile. Finally got it to release and wanted to know if anyone had any tricks for this feature .... YM2020 power shift 2wd.
   / Crawl locks up #2
Did you try easing out on the clutch a little? Sometimes especially in real low gears the gears will bind. Putting a little movement to them will ease that binding. Might have to use forward and backward movement.
   / Crawl locks up #3
My creep gear is hard to get back out of too. I find backing up a little helps but I think its the nature of them that and they don't get used much so they probably tend to be sticky and tight.
   / Crawl locks up
Thanks for the tips !! I think part of my problem the other day was that I was on a very slight slope when i was trying to get out of crawl. Tried it again today and for what it is worth going into reverse helps get the crawl knob to pop up. My fear was that I would have to use the tractor in creep to get it back to the barn. For all I know it may never have been used very much.
   / Crawl locks up #5
Oh man just the thought of having to use creep to get back to the barn... that could take up a few vacation days! :D
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
2016 Bobcat S850 (A50123)
2016 Bobcat S850...
Truck Wheel Fenders (A51692)
Truck Wheel...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
