Crankshaft seal replacement Kubota L4740
   / Crankshaft seal replacement Kubota L4740 #1
jshwhite
Missouri
Kubota L4740
Anyone have experience replacing the crankshaft seal? Kubota L4740, but I'm guessing other models are similar. I've searched around here and online and can't find much info. I'm guessing it's just a matter of taking all the front stuff off, including radiator, pulling the pully, and swapping the seal. But I know some of these have a collar or ring that needs to be replaced at the same time.
Any help appreciated. Mine's sprung a leak and is getting oil everywhere :mad:
I got the seal changed out today, so I guess I'll answer my own question here for the benefit others who have the same repair.
This is the front crankshaft oil seal I'm speaking of. There are no other collars involved - just the seal.
Getting to it takes some time.
- Grill guard, headlights, plastic shrouding, battery, oil cooler, and radiator all have to come off.
- Two steel hydrauling lines going to the steering valve have to be disconnected and pushed to the side.
- The nut on the pully is 46mm and requires a deepwell socket - ideally on an impact wrench. Good luck finding a 46mm deepwell! I ended up using a 1-13/16" on a breaker bar with a chain wrench to hold the pulley. Not the perfect fit on the nut, but it's not too terribly tight.
- Remove the pulley. I used a 3-jaw puller and it slid right off.
- Now you can access the oil seal. I didn't have a seal puller, so I just screwed a small self-tapping screw into it, clamped some vice grips to it, and pulled it out.
- To tap the new one in, I suppose there's a tool for that, but I didn't have it :) A deepwell socket isn't long enough. So I used a small block of wood with a hole the size of the shaft drilled in it, then put a deepwell socket against it and tap it in.
- Reassemble.
Hope this helps someone.
   / Crankshaft seal replacement Kubota L4740 #3
Appreciate the write up!
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
Ez-Go Shuttle 2 Electric Golf Cart (A50121)
Ez-Go Shuttle 2...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
Ficklin 4500 Gravity Wagon (A50774)
Ficklin 4500...
2016 GMC Savana (A50120)
2016 GMC Savana...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
