Craftsman ZTS 7500
   / Craftsman ZTS 7500 #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
The front wheels on this ZTR model 107.27788 (44") or model 107.27790 (50") have bushings and not bearings which will wear out if not greased each time and/or in a sandy area. The owner's manual and Sears parts direct manual does not show the bushings (2 for each wheel). I had to call Sears - The bushing part number is 1739281YP. Also make sure you check the tube (caster wheel spacer) #7035359SM which is listed in the manual.
You do not have to buy the entire wheel as the manual shows for $77.
To check if you need to replace the bushings and spacer, jack up the front wheels and check for excessive wobble. The tube just pulls out and bushing can be punched out from the opposite side.
I don't know why the wheels would not have bearings. ??
   / Craftsman ZTS 7500 #2
bushings are cheaper!
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
LINDE WELDER (A53843)
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2011 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2011 DRAGON...
