Craftsman Riding Mower Sputtering when engaging blades
   / Craftsman Riding Mower Sputtering when engaging blades #1
fisher60
Appomattox,VA
Craftsman riding mower
I have a Craftsman Lawn Tractor 26.00 HP, 54' Mower and the Model No. 917.389903. It starts up fine, but whenever I engage the Mower Blade, it starts to stutter, and then will go away when I disengage it. I have changed the fuel filter and spark plugs. It still does it. Thanks for any help.
   / Craftsman Riding Mower Sputtering when engaging blades #2
Maybe check the compression. I had the same mower up until three years ago when it threw a rod.
   / Craftsman Riding Mower Sputtering when engaging blades #3
If it fires up fine and moves around OK prior to engaging the blades, then I would say that it's the 'load' of engaging the blades that is where the fault lies.
Perhaps removing the blades and checking that nothing is fouling the ability to rotate? It's amazing what can be picked up and tightly wrapped around. For me it's the odd bit of baling wrap and horse tail hair.
   / Craftsman Riding Mower Sputtering when engaging blades #4
Run some Seafoam in your next tank of fresh fuel. This product has solved many a problem for me over the years. Be sure to only use premium fuel. If you do solve the problem, run the Seafoam through a tank of fresh fuel a couple of times in the season. Hope this helps.
   / Craftsman Riding Mower Sputtering when engaging blades #5
How's your battery ? The load on the electric clutch will do this too if the battery is weaker. The clutch takes a lot of juice to make it run and takes away from the ignition system if the battery is not so good.
Steve
   / Craftsman Riding Mower Sputtering when engaging blades #6
Welp, it's been just over two months since the OP posed his/her question... that's a lot of grass that's grown since & no follow-up if the problem was solved.
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
UNUSED White Metal Roof Panels (A53117)
UNUSED White Metal...
Lift Gate (A52377)
Lift Gate (A52377)
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
