Craftsman Rider Hot start
   / Craftsman Rider Hot start #1
tld
Boston, GA
JD 2025r
My 10 year old Craftsman mower cranks right up when cold. However, after stopping, it will not start. It cranks fast, but wont start. It smell like it is getting too much gas. I have the choke in and idle down.
Any ideas?
   / Craftsman Rider Hot start #2
When it gets hot and will not start pull the spark plug, hook it to the plug wire, and lay the plug on top of the motor. Crank it to see if it is getting arc. It it is getting spark then you have a fuel problem. Make sure your gas cap is venting. Take the gas cap off and try to start it. You could have a bad float needle or gum in the carb. It wouldn't be a waste of money to rebuild the carb on a ten year old motor.
   / Craftsman Rider Hot start #3
Try cranking with throttle fully open..
   / Craftsman Rider Hot start #4
I think a compression check is in order, as well.
   / Craftsman Rider Hot start #5
Had Sears tractor did the same thing,had choke push all the way in but butterfly plate?? was still partly close..spray cleaner inside cable plus butterfly plate work fine.
   / Craftsman Rider Hot start #6
the suggestion to lay the spark plug on the head and crank to check spark is a good one until you have one that has pooled fuel in the cylinder and you light it. nice little fire.
   / Craftsman Rider Hot start #7
Right after you try and hot start it, pull the plug. If the engine is flooding like you think it is, the plug will be wet and smell like gas.
2014 VOLVO VHD DAYCAB (A50854)
2014 VOLVO VHD...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
