Craftsman Mower project
   / Craftsman Mower project #1
lawnduster
Bronze Member
Central NH
CAT 966, Case 580
I have a 70's Crafstman Lawn tractor and am wondering how can make it go faster
   / Craftsman Mower project #2
Change the ratio of the drive belt pulleys, if its belt drive.
Remove the governor, ive seen these engines revv up to 6000, normal is around 3000rpm.
New speedy gearbox
Bigger wheels
Neutral down a steep hill
to name a few....
thanks
   / Craftsman Mower project #3
Put a FOR FREE sign on it. It should go real fast.
how do I take the governer off of it
   / Craftsman Mower project #6
if you push the throttle butterfly on the top of the carb and see which linkages it moves. disconnect any that arent the cable coming from the hand throttle. OR, set up a new cable going staight to the butterfly to a foot throttle of whatever. This would be better
WARNING, if you revv your engine too much it will blow, this is VERY likely if you revv to 6000, it is very cool when it does blow but gets $$$ fast!
either way, have fun! /forums/images/graemlins/cool.gif
Dave, very good, got a chuckle! /forums/images/graemlins/grin.gif
   / Craftsman Mower project #7
</font><font color="blue" class="small">( how do I take the governer off )</font>
<font color="red">Can anyone say BOOM!!!</font>
   / Craftsman Mower project #8
lawnduster, whats your plan for this tractor, is it gunna be a racer or do you just want it to travel faster transport. Youre looking at some serious damage if you mess up with removing the governor. With my statement about the engine revving to 6000, that was about 10 seconds before it blew up and put the piston through the head, very impressive but it did cost about £400 (race tuned honda kart engine). I mean there may be a less dangerous way depending on what you are planning.
I think Slammer has it summed up.
I got this tractor for free. It already had the deck removed from it and, after some carb work, I finally got it to run. All it needs is a new battery and It will be in gd cond. I want to find some way to make it go faster and just have fun on it, and maybe race it.
How much would a "new speedy gearbox" cost
PALLETS OF HEAVYEQUIPMENT (A53843)
PALLETS OF...
2005 EZ GO Textron Golf Cart (A53117)
2005 EZ GO Textron...
Engel 20' Boat (A50121)
Engel 20' Boat...
2019 Freightliner M2 (A53422)
2019 Freightliner...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
