mjepk
I have a 21 hsp craftsman LT1000 who's mowing deck was shot. I picked up a used 17 hsp. LT1000 for next to nothing (newer model). I was hoping to hook up its mowing deck to my 21 hsp. tractor. It wouldn't fit. I should have checked out the Sears manuals on line. The two decks have different part numbers. So now I'm trying to get the 17 hsp. tractor working so I can cut my grass. Upon starting, the 17 hsp tractor seemed to burn off lots of oil or other stuff, but after a minute it seemed the exhaust was clear. But, the tractor wouldn't run for more than 5 minutes without stalling (running with choke on seemed to help). I replaced the solenoid, spark plug, changed oil, and the tractor now runs well. It didn't smoke at all upon startup. I thought all was well.
THis morning, I went to start the tractor but the battery didn't have enough power. But, when I left the key on the "on" position without the engine running, gasoline came out of the exhaust -- lots of it. It was a steady flow rather than a sputter. I charged the battery and I also put a cut off valve on the gas line. (Note the tractor does not have a fuel pump.)
I checked the oil -- it didn't seem to have any gas in it. I couldn't smell gas in the oil, and the dipstick registered a normal level of oil. I was able to start up the tractor and it ran well. Before I shut the engine off, I cut off the fuel using my newly installed fuel cutoff valve when I was done.
Do I need to worry about gasoline getting into the oil? Or if I cutoff the gas before I turn off the tractor will it be OK? Is there something else I should do. I suppose I could take the carb off and clean it, but the tractor starts right up and seems to run very well.
