Craftsman LT-1000 16 horse charging system
   / Craftsman LT-1000 16 horse charging system #1
w0lf215
Craftsman LT-1000
Can anyone tell me what color, or which wires run the charging system for this. The mower runs and starts as long as ive got jumpers connected(no battery atm) soon as i disconnect it dies. Any ideas whatsoever? Thanks!
   / Craftsman LT-1000 16 horse charging system #2
the voltage regulator requires 12 volts input from the battery to operate. when you remove the jumper cables the voltage regulator closes and then you lose power to the anti afterfire solenoid which shuts off the fuel and the engine dies. you are lucky it is not a fuel injected kohler because it will blow the computer when you disconnect the cables because of a voltage surge.
Where exactly is the voltage reg located and what does it look like.. Thanks!!
   / Craftsman LT-1000 16 horse charging system #4
Should be bolted to the engine somewhere, with a couple wires coming from it....maybe yellow.
JOHN DEERE 6135RW401 MOTOR (A51247)
JOHN DEERE...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
