craftsman lawn tractor problem?
   / craftsman lawn tractor problem? #1
stevend
Hi, I have a 1988-89 craftsman lawn tractor. Orginally had a 11 and the owner said he put a 12 horsepower the engine is 4 years old. Bought the tractor this past september and has worked fine and started acting up about a month ago.
The problem occasionally when riding up a hill or on flat land after riding it a while the engine will start to lose power and will then die. Sometimes it will start right up and sometimes has to sit for awhile before it will start again. It doesn't do this everytime either.
The tractor usually takes some time to get it started, and goes to a high idle when warm.
I'm thinking something wrong with the carb? Any Ideas what to look for?
thanks
   / craftsman lawn tractor problem? #3
what brand engine do u have
Hi, I have a briggs and stratton engine.
   / craftsman lawn tractor problem? #5
Sounds like it could possibly be a gasket leaking. check were the carb hooks to the intake manifold, also were the manifold hooks to the engine as well as the head gasket. i have seen air leaks develop when the engine gets warm especially with the plastic intake manifolds. if u have the plastic intake manifold, the gasket mounting surface will warp if the mounting bolts are over torqued.
   / craftsman lawn tractor problem? #6
If the gas system is no gravity feed then there is a fuel pump. My fuel pump went out after about 300+ hours of operation. It first started showing symptoms when the fuel was low and would quit at a higher fuel level over time. Once I replaced the pump all was well again. After changing fuel filter cleaning fuel lines then look for a fuel pump.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
1985 Ford Ltl9000 Tender Truck (A55301)
1985 Ford Ltl9000...
2009 Sterling AutoCrane 10006H 5 Ton Mechanics Crane Truck (A52377)
2009 Sterling...
2011 Retesa CT7622 150 Vacuum Tanker Trailer (A52377)
2011 Retesa CT7622...
