Craftsman 2-cycle trimmer varying RPM at full throttle
   / Craftsman 2-cycle trimmer varying RPM at full throttle #1
bkenobi
Monroe, WA
NH T1510
I had an issue with the carb purge system on my ~10yo line trimmer power unit (check valve must have been partially blocked). I swapped out for a similar Walbro WT carb from my spares box and the motor spun up great and ran without incident for 15 minutes of testing/clearing leaves. I noticed that after 5-10 minutes the RPM started to vary slightly. I wouldn't call it surging, just slowly up and down a bit. It didn't cause me any issues with what I was doing, but I'm curious if anyone has any thoughts on what might cause this? I can do more research but not even sure what to search for to understand the potential problem.
I'm getting to the point in the year where I won't need it. I just have to get the leaves moved in over the next few weeks and then I can do any needed maintenance. Now would be a good time to test things and order parts so I can fix after it's not needed and before spring.
   / Craftsman 2-cycle trimmer varying RPM at full throttle #2
Should be a high speed adjustment screw. I bought an assortment kit that fits all the different crazy screws on carbs.
I've adjusted many carbs on line trimmers including this carb when it was on the last trimmer. I was actually surprised it worked great without touching the adjustments. I don't think this is something that can be adjusted by the high/low/idle screws though.
   / Craftsman 2-cycle trimmer varying RPM at full throttle #4
Really? Play with the high speed screw. back it out just a scooch until you KNOW the engine is running fat (Won't really rev up and sing) Then tweek it in , just a bit.
Wavering at is a sure sign of lean condition.
Huh, ok. Ill give it a try. Doesnt hurt to give it a go. Figured if it was stable for several minutes it could be something else. But then, they are pretty simple so not sure what it could be. Thanks.
   / Craftsman 2-cycle trimmer varying RPM at full throttle #6
Any chance the exhaust screen is carboned up a bit?
When i started having problems starting it after the first tank that was one thing i looked at. Worth checking again though.
2009 Pontiac G6 Sedan (A55853)
2009 Pontiac G6...
New/Unused (1) Pallet of Ground Protection Mats (A54865)
New/Unused (1)...
(INOP) 2018 BOMAG BMP8500 WALK BESIDE COMPACTOR (A52706)
(INOP) 2018 BOMAG...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
