3-Point Hitch Cracked metal hydraulic line
   / Cracked metal hydraulic line #1
nightnurse
Kubota B2400
I have a 15 year old Kubota B2400 HST, with a crack in the metal hydraulic line to the 3 point lift arms. Can this metal line be replaced with high-pressure rubber hose, and if so, what pressure rating should I use?
   / Cracked metal hydraulic line #2
Not sure about your Kubota, but most tractors run 2750 PSI or higher. Check with a local dealer, they may be able to replace or reccomend someone that can repair or make a new line. New line can be flexible and that is OK.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
2006 Lexus ES 330 Sedan (A51694)
2006 Lexus ES 330...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
Unused Delta Crash...
