Cracked engine block
Status
Not open for further replies.
   / Cracked engine block #1
jpbear
West Virgina
NH TC40DA
I have a NH 1630 w/ FEL. I was using it today and saw some oil under it. After closer inspection I noticed that the block is cracked. Probably happened because of the front weights I put on (and never took off) when I skid logs using my rear grapple. All to bouncing cracked to engine supports that eventually cracked the block. I believe it can be welded. Does anyone have and experience in doing this? What type of wire or rod shoudl be used? If welding does not work is there a place to get a short block for this tractor? I post this thread under Repairs in the main discussion area also but wanted the New Holland people to look at it also. Please go to that thread to see the photos.
Thanks,
Joe
Status
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
toro turf sweeper (A50324)
toro turf sweeper...
