crabgrass in my bermuda
   / crabgrass in my bermuda #1
anthonyk
houston texas
Century 3647
I've got bermuda grass in the yard immediately surrounding the house. The grass guy who sold it to me said it was called "Tif" bermuda if that matters. I love the grass, but because the yard is surrounded by fields and woods, I get a ton of weeds and especially crab grass. Most of the weed killer or control products I've seen are only for St. Augustine, and say specifically NOT to use on bermuda. The few I've tried (Greenlight MSA crabgrass killer) say they're safe on Bermuda, but always leave a big dead yellow spot where I use them.
Any ideas/suggestions?
Thanks, Anthony
   / crabgrass in my bermuda #2
I use to get crab grass alot.Went to my local lawn & garden center& the owner sold me Ferti-Lome brand bermuda weeder. Mix it with water( use pump type sprayer) Mix it a little stronger than it states & spray the crab crass only.In 2-5 days crabegrass will be dead.Not sure but I think temp. has to be above 80 degrees to work.It works well with other weeds also.
   / crabgrass in my bermuda #3
The MSMA generally works well for me in my bermuda. During really not weather it does yellow the bermuda some but does not kill it. Maybe you are putting it on too strong.
I think probably the best way it to put down a recommended pre-emergent in the winter. I keep saying I am going to do that but in mid winter the lawn is the last thing on my mind.
   / crabgrass in my bermuda #4
BB_TX
What rate to you apply MSMA at and see the best results? I'm going to spray next weekend for the first time. Rates range from 1 oz per 1000 sqaure feet to 2 oz. I don't want to go too high and burn my bermuda, but I want to get all the weeds.
   / crabgrass in my bermuda #5
John - I don't remember ( I seem to have more of that lately /forums/images/graemlins/crazy.gif). I haven't bought any yet this year. I do remember following the recommendations on the bottle. Don't even remember for sure the brand, but I think it was Greenlight. Have bought it both at Walmart and HD. It works best on the crabgrass if the temp. is above 80-85 without yellowing the bermuda too much. But if the temp is 90 or more, seems the bermuda will yellow more. I pretty much just spot spray rather than general broadcast spray. That keeps whatever yellowing there may be to relatively small areas.
Yep, I was using 3 teaspoons in 2 gallons of water per instructions by greenlight, but still turned the patch that I sprayed yellow. /forums/images/graemlins/confused.gif
anthony
   / crabgrass in my bermuda #7
I will have to buy some more and look into it. I was thinking I mixed it more like 1 tablespoon to 1 gallon, but not sure. It may be that the Tif is more sensitive to it than the common bermuda that I have got. Tif is used a lot on golf courses. You might ask a local greenskeeper what is best to use.
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
