Couple of questions on the BX Series
   / Couple of questions on the BX Series #1
JonLeonard
Huntington, WV
Kubota B2410
I took some time this weekend to visit a local Kubota dealer and test drive a BX1800. So, I have a couple of questions that the dealer didnt answer to my satisfaction.
Is it possible to add a remote valve to the rear of the tractor? I want to build a hydraulic dump wagon and need a place to hook it up.
Is it ok to use the 60" mowing deck on the BX1800?
The dealer told me, that they is no noticable difference between the power of the 1800 and the 2200. Can anyone confirm/deny this?
He also said that he would suggest getting a B7500 if I wanted to use a post hole digger. Anyone used one with a BX, and if so, what size of auger?
Lastly, I noticed from reading on these boards, that the loader valve that comes as standard equipment is a 3 way valve. Supposedly the 4 way one is a $60 upgrade. Does that mean that the load has no down pressure?
I would think that is Kubota is planning the add a backhoe to the list of options for a BX, then the loader would need down pressure in order to level/stabilize the tractor.
Jon Leonard
Newbie Tractor Operator and Information Gatherer
   / Couple of questions on the BX Series #2
I can only answer a couple of the questions.
It looks to me that you SHOULD be able to add a remote, there is even an unused lever area on the rt hand fender...in my inexperienced mind, that tell sm that that it should be available.
Yes, I have seen where people have put a 60" deck on the 1800. Tall grass may affect you more than if you had the extra HP of the 2200, but I can't say for sure. The owners manual only shows a couple of differences in recommended attachments between the 2200 and the 1800, width of tiller is one of them if i remember correctly. I would think that the 1800 can handle everythiing the 2200 can do, if perhaps smaller bites of whatever you are doing. On occasion I've strained my 2200, and was glad of all the torque I had.
The loader does have down pressure, in conjunction with a float position. I can lift the front end off the ground and was unaware of any other option. I would be at a loss as to what may be missing, actually, since a 4-in-1 bucket isn't available in the BX as far as I am aware...
Kubota is coming oout with a backhoe, and I have rented a post hole digger (9") that worked just fine. Any bigger diameter may need more power, though.
   / Couple of questions on the BX Series #3
I alos rented a post hole digger--worked fine. I should think the 1800 can handle the 60 inch since the 2200 handles it with such ease it is too bad there is not a 72 for it. I have the 4-way valve. You should go ahead and get that and it was about 60 dollars more. Yes, downforce is available with the lever pushed up till you get to the float detent and then it is gravity alone. J
   / Couple of questions on the BX Series #4
Trescrows,
what's the difference between valves? I didn't know there were any options on it....Mine has 5 positions: Roll back, dump, raise, power lower and float.....
I am wondering now if I really know as much about hydraulics as I thought I did.
I was assuming 1 "way" for raise, 1 for lower, 1 for curl, and 1 for uncurl. For a total of 4 "ways" with a 4 way valve.
Can someone give me the 50 cent explanation on how this really works, and how the "float" plays into it all?
   / Couple of questions on the BX Series #6
Instead of me always asking questions maybe I give an answer for once.
I had inquired about the 4 way valve option and this is what I understand it to be. The four way is used if you plan on buying any Kubota "quick attach" front mounted implements (snowblower, front blade, etc) I believe the option (which is available as a kit) would include some sort of mount/support because when you back out of the FEL to remove it, you also are removing the control valve assembly.
My BX 2200 is arriving this Wednesday so I am not talking from experience, only repeating what I was told. I'm convinced, since I'm not interested in the blade or snowblower, to order mine without the option. BTW, the valve costs $160 more list.
David
   / Couple of questions on the BX Series #7
Float allows for it to follow the ground surface, without downward pressure. As the contour rises and falls, so does the FEL on the surface. Comes in handy for doing things like picking up loose material (so it doesn't dig in to the turf), or for grading when pulling back loose soil.
Roy
   / Couple of questions on the BX Series #8
<font color=blue>because when you back out of the FEL to remove it, you also are removing the control valve assembly</font color=blue>
David,
It's my understanding that the BX FEL control is pretty much the same as the B series. On my B7500 the control assembly (spool valves, joystick, & mounting bracket) stay with the tractor, not the FEL. The hoses disconnect right at the control, and the hose stays with the FEL.
The GlueGuy
   / Couple of questions on the BX Series #9
I may be incorrect in this but here is what I am reading, the 4-way has a two-stage dump, to the right is regular and further to the right is has greater dumping speed, the first position should be used when operating a front blade or similar with the loader valve. The positions are seperated by a feel position. I could be entirely incorrect. J
   / Couple of questions on the BX Series #10
I don't know for sure, but I'm pretty sure you've got it right, TresCrows.
And GlueGuy, on some tractors the joystick and valve stay with the loader instead of the tractor, and I think that's the case with the BX series. Some of these BX owners will know for sure.
Bird
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A51572)
2004 International...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
