Couple 2615 questions
   / Couple 2615 questions #1
marvin494
First off I apparently had the factory drawbar stolen from my tractor. This is the bar that goes into the receiver type hitch at the rear axle. I have spoken to two different dealers and they both quoted me $230-$240 for a new one. I find it hard to believe that a flat bar with 3 holes in it could bring that kind of money. So my question is does anyone know if this is correct? If so there's no way I'm going to pay that. Does anyone have one they could take some measurements of for me so I could try to make one or have one made?
The second thing is my foot throttle is sticking. Is there a place I should try to lube the cable to help it out?
Thanks for any help you can give
   / Couple 2615 questions #2
Check out your local TSC store. They have a couple different types or you can probably get one made for a reasonable price. Check Amazon for tractor drawbars. I saw a bunch of straight ones there for $150 down to about $50.
CountyLine Drawbar, Swinging - For Life Out Here
I had a 2615HST so no foot throttle but should be fairly easy to look underneath. Probably a grease fitting there that was missed. If no fitting then lube any pivot point that moves while pushing the throttle.
Thanks, I took a look at tsc the other day but I guess they have some things online that aren't in the store.
2001 Ford F150 (A50121)
2001 Ford F150...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A52748)
COOPER LIGHTING...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2017 Volkswagen Jetta Sedan (A50324)
2017 Volkswagen...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
