lhfarm
Veteran Member
I made the road trip to Fredericktown, OH (about a 10 hour round trip) to pick up a 2 ton dump trailer from Country Manufacturing. Beautiful drive and the wagon was assembled and waiting for me when I arrived. I've read enough here to know exactly what to expect - a nice trailer for the price.
I hauled the trailer home in my 5x10 utility trailer without any problems. I stopped on my way home and purchased a 24"x4" cylinder from the local Rural King store, along with hoses and a control valve (two-way like used on a spliter (all they had)) for an old 12v pump I had on hand.
Since they had assembled the trailer for me, I thought I would get started right away. Getting the cylinder mounted was much tougher than I expected. The fit is perfect, but I think it is really a two person job. Not having an extra set of hands, I used the FEL and a chain to raise the trailer bed high even to give me some working clearance. That worked great for the case end. Attaching the the ram end was harder, in part because I didn't have fine enough control to extend the cylinder (more on this later). I finally used a farm jack to raise the bed slightly and by playing with extending and retracting the rod got the second pin in.
The plan is to load the trailer with my backhoe (the TC40DA is parked in the background) and use my jeep or Cub Lo-Boy to tow the trailer. So I need a self-contained hydraulic unit. As stated above, I had a pump + reservior that I had purchased for another jeep project. As can be seen in the picture, the pump will lift the bed, but I can't seem to fully extend the cylinder.
I don't know much about the pump - an e-bay purchased and I don't know much about hydraulic systems either. Before I mounted the cylinder, I tried to fill the cylinder and hoses with hydraulic fluid (I used the NH fluid, since I will be using the TC40DA to pull the wagon sometimes). I had to fill the reservior a few times before the ram would move.
First question - how do I know when the system it full - should the reservior be filled to the top when the cylinder is fully retracted?
Second question - Since this is a closed system, how do I bleed the air out? Loosen a connection? There is a 1/4 inch plug in the reservior tank. Is that for bleeding the system?
Third question - Why isn't the cylinder fully extending? Is the tank large enough for this cylinder? Pump too small?
The setup does work, but I am going to be loading very heavy cattails that I am digging out of my ponds. What would should I try next?
