Could a 541 loader be fitted to a 6120 4WD
   / Could a 541 loader be fitted to a 6120 4WD #1
meyersd
high range,NSW
JOHN DEERE 6120
Hello, I have a JD 6120 & want to fit a loader
Have access to a JD 541 loader at a good price. This came off a 5520 JD tractor
Know I will need to modify or replace the base mounts, but are not fully sure if loader itself will fit, eg mount pivot to cross bar clearance for bonnet, pivot width, etc.
Any info would be greatly appreciated.
David
   / Could a 541 loader be fitted to a 6120 4WD #2
I am thinking it will prove too small. You will also have to check front tire clearance if you have MFWD. I would look for a 620 if two wheel drive, or 640 for either two wheel drive or MFWD
Thanks for that
Much appreciated
   / Could a 541 loader be fitted to a 6120 4WD #4
I agree with Zebrafive that a 541 is too small for a 6120
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
Year: 2008 Make: Toyota Model: Tundra Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door (A51692)
Year: 2008 Make...
2013 Freightliner M2 106 Water Truck (A53117)
2013 Freightliner...
