Spreader Cosmo fertilizer spreaders
   / Cosmo fertilizer spreaders #1
Donnyj
Platinum Member
Southern Pa.
Looking
I was wondering if anybody uses the Cosmo brand of fertilizer spreaders? Any info on the brand would greatly be appreciated. I'm looking at some of there fertilizer spreaders and was just wondering what other members think. Thanks in advance.
   / Cosmo fertilizer spreaders #2
Fair quality, not the most accurate metering of all the spreaders on the market (especially with grass seed) , but does fairly good for the buck. Holds up to fertilizer about as well as anything for the average user. (They ALL rust in time) Keep it clean when not using, oil any bare metal surfaces after using, and you shouldn't be disapointed. I've had one for about 7 years. No complaints.
Thanks for the info. My usage would be maybe 20 acres a year. Are the gearboxes aluminum or metal? Are they oil filled as well?
   / Cosmo fertilizer spreaders #4
Gearboxes are stamped metal of some sort (aluminum or stainless), that doesn't rust. The operator's manual is available online. Go to Landpride.com and select Manuals on the upper tool bar>> Spreaders...
Also, a TBN thread entitled, Re: Cosmo 500, Gear Box Lube?, might be helpful.
After putting in several shots of grease, I finished filling the gear box up to the zerk with 90w Gear oil. As CCM said in the thread above, there is a retention problem using gear oil (the oil leaks a little at the mating surfaces of the gear box housing). But, the leakage is minor so far, and, with gear oil onbroard, I'm confident the gears are getting lubed.
My main concern with the Cosmo is that the agitator spins in contact with the floor of the spreader and wears the paint off in just one load of fertilizer. It seems to me that a thin spacer between the agitator and the floor would help protect the floor. I went to the extreme and had Line-X spray the inside of the spreader with liner, and use a 1/8" thick, high density plastic spacer between the agitator and floor. So far so good. It seems like with these extreme precautions the spreader may hold up for a while.
OkieG
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
Butterfly Artwork (A55758)
Butterfly Artwork...
30in Forks and Frame Mini Skid Steer Attachment (A55851)
30in Forks and...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
