Corrugated roof leaking
   / Corrugated roof leaking #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
The barn has roof from corrugated roofing panels, not steel but the glass fiber stuff available at home depot and such places. Recently it developed a leak, is there a paint to patch it up with? Like flat roof cement? I would like to make it last till spring and than replace it.
   / Corrugated roof leaking #2
Leaking at a nail or crack. About anything that would stick would work. Silicon, etc.
   / Corrugated roof leaking #3
If it is a hole too large for caulking or sealant, make a patch with a small peice of panel using butyl tape at the edges, overlay it and screw it in place.
   / Corrugated roof leaking #4
If you are going to replace it next spring anyway, then go to your local hardware store and get a gallon of roof cement. I bought mine at HD. It can be applied with a brush or trowel and can be applied when wet (read the can since there are some that can't be applied while wet). I used it in the past to get another year out of my roof and it stopped the leak.
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
2015 Ford Transit 250 Cargo Van (A55788)
2015 Ford Transit...
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
2005 Mitsubishi Lancer ES Sedan (A55853)
2005 Mitsubishi...
2018 John Deere 325G (A47477)
2018 John Deere...
