corrosion on 3720
   / corrosion on 3720 #1
joblow
laval, quebec
jhon deere 3720
As any one of you had any corrosion problems on the rear axles exactly where the cabine posts sits on the axle ?
corrosion occures between the posts plates (steel) and the axles (aluminium).
Since the two metals are in contact they form electrolysis and form corrosion to the axles.
Last year i got both sides changed (12 000 $) on one of my machines.
Since it is a conception problem, John Deere paid for half the bill.
I noticed the same problem this year on two other machine they are 2005 and 2007 (not so old )
The corrosion made a hole big enough to stick two fingers Inside the axle casing :eek:
I hope John deere will make a recall for that problem but i did not ear anything about it.
   / corrosion on 3720
worked all day cleaning and painting my #6 tractor to get it ready to go to the dealer and get the rear axles casing changed.
i was hoping to get a reply about any recall from JD on the forum. (no one seems to to have that problem )
Corrosion on rear axle casing where the cabin posts sits ..
It will cost me 12 000$ for a engenering conception mistake. :mad:
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2013 Doyle Dry...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
UNUSED RAYTREE RMDM70-70" HD DISC MULCHER (A51248)
UNUSED RAYTREE...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
