Correct Tire Pressure
   / Correct Tire Pressure #1
twdrums
Franklin, TN
Ford 1520
I have a Ford 1520 3-cyl Diesel. My front tires have the stated psi, no worries. However, the rear tractor tires don't seem to have spec's anywhere on them.
The tires are Firestone F151A, but I can't find the correct psi listed
Help anyone ??? My family are all machinists and incredribly mechanically inclined, but I got the music gene and live here in Nashville metro now.
The last thing I want to do is call them for help, I've taken enough ridicule over the years !!!
Thanks for the help.
Tommy
   / Correct Tire Pressure #2
I don't own that model, but I'll for the fronts whats printed on the tire is most likely the maximum. It's what you would want with a front end loader. If you do not have a loader you will want less pressure. For the rears try 14-16 psi. Fronts 20-24 psi.
Someone with your model will be better able to give correct pressures.
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53472)
2012 NEW HOLLAND...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
